mais eu le covid avant de pouvoir faire la 3 eme dose? car je n'y comprend plus rien d'un pays à un autre tout chance même les tests pcr on ne sais plus ou donner de la tête
merci
Pour aller aux Etats Unis, il faut présenter un schéma vaccinal complet :
https://www.cdc.gov/coronavirus/2019-nc ... ation.htmlAre you Fully Vaccinated for Air Travel to the United States?
You are considered fully vaccinated :
- 2 weeks (14 days) after your dose of an accepted single-dose vaccine
- 2 weeks (14 days) after your second dose of an accepted 2-dose series
- 2 weeks (14 days) after you received the full series of an accepted COVID-19 vaccine (not placebo) in a clinical trial
- 2 weeks (14 days) after you received 2 doses of any “mix-and-match” combination of accepted COVID-19 vaccines administered at least 17 days apart*
If you don’t meet these requirements, you are NOT considered fully vaccinated. A booster dose is not needed to meet this requirement.
A person who has received only one dose of an accepted 2-dose series and has recovered from COVID-19 does not meet this definition, and therefore is NOT considered fully vaccinated for travel to the United States.
Je suis dans le même cas que toi. Pour se rendre aux US c'est OK avec 2 doses + le test à faire la veille.
Il ne me semble pas avoir entendu que les règles avaient changé .. donc oui il faut toujours le test sauf si tu as eu le Covid dans les 90 jours qui précèdent ton départ
